Team Dynamics 15x8+35 with Swift springs and 225/45R15
Highlands Ranch
Hey guys! I might be needing a new set of summer tires soon. I have a set of Team Dynamics 15x8+35 and was planning to buy a set RS4 225/45R15 and also get Swift springs. I have researched about this setup but I was just wondering how much does the tire stick out from the fender? Pics will be much appreciated! Thanks in advance!
L
Highlands Ranch
Anchorage
How do you like the B6s and Swift springs?
I like the setup quite a bit! The setup is a bit too stiff for our crappy roads up here, but I did pretty well with this setup in autocross. It does sit low, especially on the racing rubber- that extra 1/2 inch does make a difference. I daily it on the stock wheels and tires, and even then, I've bashed the heck out of my 2 point bar.
I've wanted this setup, but the above just confirms that it would NOT work for me, as I must take this car down gravel rally stage roads when working/volunteering on such, and even with a skid plate, a setup with this low a ride height is just NOT 'doable' for me. [:(]
L
Highlands Ranch
Good to know. I was planning to daily the RS4 when I buy it. The RS4 is the only tire in the 225/45/15 size that would last. You are referring to your track bar when you said 2 point bar, right? From Plainrt's pics, it doesn't look low at all.
Anchorage
Yeah, I wish Swift had a slightly less extreme option- a bit higher, a touch softer- to really make it more of a practical car. Plowing through snow- or the slush that gets built up between tire tracks on the road where it freezes- gets old.
L
Highlands Ranch
Thread Starter #14
I heard the 2014-2015 struts/shocks paired with Swift springs feels more compliant and not as bouncy from my research. What year is your FiST?
^^^Yeah Pablo, I don't mind the rate at all (it's only ~40 in./lbs. greater than factory after all), it's the DROP that I just cannot live with, but they must cater to the 'slam it' majority, I guess. [:(]
Factory ride height, with the Swift's linear rate, or even a slight bit higher rate, would be ideal for my uses, but I guess I'm the only one who wants that in this whole country?
L
Highlands Ranch
Thread Starter #16
^^^Yeah, I don't mind the rate at all (it's only ~40 in./lbs. greater than factory after all), it's the DROP that I just cannot live with, but they must cater to the 'slam it' majority, I guess. [:(]
This surprises me as Swift doesn't drop that much. Doesn't Swift has the lowest drop compared to other springs?
Anchorage
Totally non-scientific, but here is a shot of my bar clearance while riding on stock wheels/tires with the Swift/B6 setup.
The Purel bottle is about 3.25 inches tall, so guessing about 2.75-3 inches of clearance? The 225/45R15s drop it an additional .5 inch or so.
I remember seeing strut spacers from my WRX days- I wonder if something similar is possible?
sorry this has been kinda thread jacked
L
Highlands Ranch
Thread Starter #18
Ah, I see your point now. Is that bar your trac bar? I am planning to get a TB Performance bar so it has more clearance.
Anchorage
yes- the bottle is sitting flush up against the Pierce 2 point lower chassis brace/ tiebar/ track bar thing. One thing I noticed is that the lower flexible bit of the nose is about at the same level as the bar.
