So say someone was to route a pipe over the passenger side of the engine from right out of the turbo inlet, then bolt a filter that goes through the bumper. Something similar to the attached pictures except in a completely different location. Could one potentially see even cooler aits than a behind bumper filter? Or is the negative pressure my itg is located at helping it pump air? I feel it would only be worth it for 2 reasons. 1 it wouldn't cross over the exhaust manifold, similar to the 2j and 2 only if the air temps dropped substantially by the time it hit the tb. I'd say a 30 degree difference before and after would be a worthwhile goal. What do you guys think? Would it even be possible for the air to retain that level of coolness?
