Morning, all.
There have a been several "what are my options" threads for transmissions, but they are getting old and were for folks who weren't using their FiST exactly as I do. So, hoping to get some options that are current and applicable to me.
The car: Track dedicated completely, including stripped interior and full cage. 2015 FiST with a new (used) motor, S280 on E48, Multi-Port fuel, Wavetrac LSD, 225/40/17 R7 slicks, custom front brake kit. I use the STOCK clutch and flywheel, so an aftermarket clutch setup is not to blame.
On Friday, just two laps into my first track session of the year, my transmission gredanaded. Coming out of a higher speed turn in 4th, suddenly the car felt like it was in neutral. Downshifted to third, which took . . . for a few seconds, then 3rd acted like it was in neutral. Then, came horrible clunking, marble noises, and I limped the car back to an access road and loaded on the trailer.
At home, it went into first and reverse fine getting it from the trailer to the garage, albeit making noise. For a hot second, I thought maybe it was something minor like a CV joint. But, as I put the car under load pulling it up the ramps on a 4-post lift, it made a couple more horrible clunking noises, and now the shifter won't come out of the 1-2 gate. Going theory is that broken pieces internally got lodged.
So . . . I don't think I'm interested in paying $4-5k for a Clarke. As fine as the craftsmanship seems, that's a lot for a transmission that isn't necessarily more durable for track use. Certainly, I'm not paying $13k+ for a Pumaspeed sequential, as fun as that sounds. I'm hearing a rebuild is not possible because internals are not available? I might be forced to stick with a used OEM, but that would have to be opened up anyway for the LSD install.
Note, if whatever transmission I end up with needs opened up for my Wavetrac anyway, I'd like to address having a lower effective gear ratio. I need more pull out of 3rd and 4th. Frankly, I don't care about the other gears from that perspective. At the least, perhaps the higher numerical final drive ring & pinion modification would be sufficient.
Your input appreciated. Picture for attention . . . as she sits now and likely will sit until this goat rope is resolved.
