Maybe this is an unpopular opinion, maybe others agree. Just wanted to share my thoughts on the FiST gearing. Long story short, after nearly 3 years with the car I think Ford absolutely nailed the ratios of each gear.
When I first bought the car, I remember thinking first gear was too short, second gear was a little too short, third, fourth, and fifth were fine, and sixth should have been taller. Perhaps this was because my previous car was a 2016 Fiesta SFE 1.0T with TALL gearing (for fuel economy).
After much contemplation, I really think Ford nailed all the ratios and I have zero complaints.
Maybe I've just "gotten used" to the car. But I think my time driving other (kinda similar) cars over the past year has helped me appreciate the ST gearbox. For reference, these cars have included:
- 2022 Civic Si (6 sp)
- 2014 Civic Si (6 sp)
- 2019 Toyota Corolla (6 sp)
- Mk 7 GTI (6 sp)
- Mk 4 GLI (6 sp)
- 2014 Focus SE (5 sp)
- 1999 NB Miata (5 sp)
Some of these cars feel like they're geared too low overall (Miata - although I know this is to compensate for lower HP, it would be nice to have at least an extra gear for higher speed cruising...4000 RPM on the interstate gets old). Some feel like they're geared too high (Corolla - probably for MPG, but still...). Some feel just right - most notably the 2022 Civic Si and the Fiesta ST.
Here are my thoughts, gear by gear:
1st - only too low if you're drag racing (it's a FWD econobox...). Perfect for stop & go traffic. Easy modulation to get the car moving. Perfect for a daily driver.
2nd - great for rolling starts, fun pulls up to 50ish MPH. Perfectly spaced for 3-2 downshifts.
3rd - the perfect gear for hard pulls that won't put you in jail
4th / 5th - spaced flawlessly, perfect for high speed passing in the meat of the torque band.
6th - just high enough for good fuel economy when cruising. Just low enough to still have get up & go without always needing to downshift.
Overall, for a car that's used for any type of driving you can think of, I think Ford nailed the gear ratios. The spacing is cohesive, you can stay in the power band between all gears and you can really row through all the gears without driving stupid fast. First is low enough to be great for slow speed / taking off on hills and 6th is high enough for good fuel economy and keeping revs reasonably low at interstate speeds without sacrificing too much power.
Moral of the story, I love this car. Hope mine goes many more years. I don't think there's anything out there with the same balance of budget, fun, and practicality.
- Mk 7 GTI (6 sp)
- Mk 4 GLI (6 sp)
