Ok. So, I installed a Cobb FMIC and an ATP hot side charge pipe (high flow). It all went good for a while, and today, as I was cruising on the highway, there was an abrupt pop, and most of the power was gone. You could hear the turbo spooling really loudly, so I figured that one of the connections came off, and I was running a "naturally aspirated" ST now. Indeed, the boost pressure never got past zero, but, other than the whine and anemic power, the car drove fine.
So, I got home and jacked it up to confirm, and as I stuck my face under the wheel well, I got an unpleasant surprise of oil that leaked down the plastic liner right on my mug. Sure enough, the connection between the pipe and the FMIC came off, but oil??
I will get a closer look when I lift it up tomorrow, but I am hoping that someone smarter than me would explain the oil (where from it came, for instance), and what this all means, in terms of getting things cleaned out. What if I sucked some into the intercooler? The overall amount doesn't look too much, but certainly is non trivial.
Would appreciate a word of advice on the next steps.
