Boomba Racing Universal Blow Off Valve
Premier Vendor
Proudly made by Boomba Racing Inc is our Universal Blow Off Valve made for aftermarket big-turbo set-ups or cars with the blow off valve in-line with the charge piping.
This piece is meant to be welded onto your charge piping, and operate off a vacuum source. The mounting piece is meant to be used with 2.5" piping, but will also work with smaller or larger diameter piping. This blow off valve is great for anyone running an aftermarket big turbo set-up who can no longer retain the factory style valve which bolts onto your turbo.
This high performance VTA (vent to atmosphere) blow-off valve is precision machined out of aircraft grade billet aluminum. It features an internal brass piston design and is pressure tested to withstand up to 70psi, allowing it to compliment even the most aggressive turbo builds. Spring pre-load determines the pressure differential required across the piston before the BOV opens and releases the pressurized intake charge.
MSRP: $190.00
Link for purchase: http://www.boombaracing.com/universal-blow-off-valve/
Premier Vendor
Thread Starter #2
Perfect for big turbo set-ups!
Premier Vendor
Still looking for a charge pipe mounted BOV? We've got you!
Premier Vendor
Big turbo? No problem, check out our universal BOV!
Premier Vendor
Everyone considers a big turbo at some point through owning a Fiesta ST... Our universal blow off valve welds to your charge piping and will manage all that BOOST!
Premier Vendor
All colors are in stock and ready to ship!
Premier Vendor
Looking for something a bit different? We've got you covered, with our universal BOV! Weld it to the chargepipe, install the vacuum hose, and you're done!
Premier Vendor
Perfect for those of you that went BT! Don't settle for a cheap part made in china, get our proven BOV. MADE IN USA!
