Dead Hook Motorsports Sound Symposer Delete Kit
Trader history for DHM (0)
Thread Starter #90
Just for the couple people wondering and wanted to know the differences between our kit and others on the market.
Our kit is the only kit that deletes 100% of the factory sound symposer system.
We include
- (Qty:1) 6061 Billet Aluminium Plug (powder coated for corrosion protection)(Will drill and tap for options like Meth, Nitrous, or boost reference.)
- (Qty:1) Black 4 Ply Silicon Hose
- (Qty:2) 100% Stainless Steel Liner Hose clamps (liner protects silicon hose)(most SS hose clamps have zinc bolts still; however our 100% SS clamps cost a little more but will not corrode)
- (Qty:1) Black chemical resistant cap
- (Qty:1) Long Zip Tie
- (Qty:1) Dead Hook Motorsports Green Decal (also available in pink if specified before shipping)
- (Qty:1) Detailed Instructions
Our kit does not only delete the box itself it deletes the factory hose replacing it with high quality 4-ply silicon and 100% stainless clamps. We also include a cap to delete the hose that goes be hide the battery box.
When your trying to delete your sound symposer chose the cheaper, cleaner and quality route.
Thread Starter #91
Video and Instructions posted!!!!
NorCal
#92
I see why you asked the question on the other thread. I honestly thought we wouldn't have to take out the hose going into the cabin and cap the hose itself. Makes for a simpler install and easier to reverse if need be.
Thankfully I have to install a set of transmission bracket bushings so I'll do the symposer delete at the same time.
Thread Starter #93
Yea the point of my clean is to make a very clean removal of the sound symposer. Deleting that hose and not leaving it there with a plug in it is the best way. Honestly pulling the battery and box out is super quick. 5 bolts plus the battery cables and two ecu plugs. Anyone with an aftermarket intake i would think would have enough room to get it out without all the intake removal. Also with this kit being cheaper and having everything to delete from start to finish i think anyone who got this kit and anyone who is getting this kit in the future will realize its well worth the extra 20-30min to clean up and get rid of the rest.
JPGC
Middleburg
#95
Yeah getting that hose out of the way cleans it up a lot as well as the symposer and the long hose that connects it. I have a pcv plug in the stock hose next to the throttle body while I'm waiting for the delete kit. It will look so much better with the shorter hose.
Thread Starter #96
If you look at the pics i posted you can see how much room it frees up and clean it looks! Tomorrow some guys should be getting theirs.
#98
For those of you that will be removing the battery and disconnecting the ECU, be aware that your car may act funny (A/C not working, vents not diverting properly, etc.). If this happens, disconnect the battery again and let the car sit for a couple hours to let it "figure itself out".
JPGC
Middleburg
#99
Good advice!!! I have had it happen a few times to me, lol. The first time I was cussing for half an hour thinking that I had broken something when I added the mountune shifter adapter. After searching throughout the engine bay, I disconnected the battery and reconnected it. Then took a break. When I came back and restarted the car, all was fine.
Thread Starter #100
I have only seen that happen when you dont do it in the right order
Remove: battery ground, battery positive and then ECU connectors
Install: ECU connectors, battery positive, and then battery ground
Realizing now that i did not lay that out exactly i will be updating the instructions soon.
Thank you for the post though bring up a good point.
