Down pipe bolt
Trader history for Spaceman_Spiff (0)
Spaceman_Spiff
Spaceman_Spiff
JeffCo
Thread Starter #22
I was able to get one of the good bolts threaded in to the problem hole without issue. Now I just have to find a parts department that will answer my emails so I can get a new bolt.
Sent from my Spaceship
Zissou
Charlottesville
Hi. I somehow f'd up the threads on one of the three bolts connecting the down pipe to the turbo. Is this something I will need to source from ford, and if so, can you help me out with a part number? I have no idea about heat properties and materials, etc., so I wouldn't even know where to start if sourcing locally.
Any help would be appreciated. Thanks!
I know that feeling; I bent one of those bolts changing out downpipes. Luckily I could still get it out, but it took a long time and a lot of patience (and a lot of WD40).
I just replaced it with a stainless steel bolt from Lowes and put it back in with aluminum anti seize. I might be corrected here, but I think that should be fine. I've had it on for about a year with no problems.
CanadianGuy
Southern Ontario
You just have to be very careful not to torque to much as the bolt will survive but the threads in the hole will not. I always prefer the bolt being the sacrificial part.
