Boomba Racing Catch Cans
Hijinx
U.S. Air Force Veteran
Auburn, AL, USA
True to an extent. Not to get totally off topic, but the CFM Valve Cover breather does take this into account. It has a check ball that closes off the VTA under vacuum. So, precisely when the PCV system is engaged (under vacuum) is when the breather is closed, allowing vapors to be sucked out. Then, when the crankcase is pressurized and the PCV valve closes, the check ball opens up to let the crankcase VTA.
So in other words, the vapors stay in the crankcase until you go into boost?
Edit- are you talking about the oil cap replacement?
Columbia
Yes, the oil cap replacement. And no I don't think the vapors stay in the crankcase until you go into boost. If you're into boost, the PCV valve is closed and unless you have a breather, the vapors are going to stay in the crankcase. Once off boost, the PCV valve is open, closing the breather and venting the vapors through the catch can. Thus, with a crankcase breather you're venting all the time, not just when the PCV valve is open.
[Edit for clarity.]
Etyrnus
Nowhere
[Edit for clarity.]
The CFM breather does have a valve in the oil cap replacement. Under normal operation it's closed, but opens under boost to vent.
Hijinx
Auburn, AL, USA
[Edit for clarity.]
Ah, I see. It would be a good (although, toxic) addition to a catch can.
Trenton
So I feel this may have been answered another way but , wld it be best to have both ? The can and the breather? Or just the breather? Please clear it up for me. Im new to this motor. Thx guys.
Thread Starter #126
Shooting for a release very soon! Ran into some last minute production delays but do not fear, Boomba is here!
San diego
I was actually wondering what the difference between this and the Mishimoto one is.. Other than having 3 outlets
Thread Starter #131
The can actually has two inlets and two outlets, so it is user configurable. This can is also large @ 350ml of capacity.
There will be a few options to purchase these cans. You can get the can with the mounting bracket all on its own, get a set-up with hardware made for the PCV side, or get a set-up with hardware made for the CCV side. We really want to give the customer all options possible.
Furthermore instead of using an insert in the can, the filtering of oil from air is actually done on the outlet of the can by a two-step filtration system that keeps the junk in the can, and clean air flowing out.
riverbank
Do you have a diagram of the double baffle setup? Does it include a bronze filter like mishitomo's? If not, does it filter better than the bronze filter?
Thread Starter #135
[MENTION=1045]Boomba Racing[/MENTION]
Knock Knock.... Any news?[poke]
Install guides are being finished up today!
Stage 1 (CCV) will mount under the intake piping near the battery box.
Stage 2 (PCV) will mount where the "box" is located for the sound symposer.
So we would have to buy 2 catch cans one for each stage? Is there any way we can T both in one?
