I was waiting a bit to review, but will add my thoughts so far. I ordered the 88 red from Whoosh and installed it about three weeks ago. I do not put many miles on my car, so I'm pretty sure the mount has not broken in fully yet. But -
If you do not want to put up with NVH, I'd probably recommend the softer 70. When I first cranked up after installation, I thought my car was going to shake itself to pieces. It does rapidly soften up, but even now that I'm probably 200 miles in, it is noticeable. At very low RPMs (like when going from a stop to a start and letting out the clutch) there is a good, healthy shake. At higher RPMs, things are a bit noisy as the engine gives the frame some good vibes. It does seem to be improving still, and the weather is quite cold, so I do think I'll see more improvements.
In the end, I'm still happy. I don't drive on the highway, and the benefits outweigh the cons for me. It may not be for everyone, but I appreciate the harshness. I didn't buy the FiST to be an easy cruiser. I can really wring out first and bang into second and the mount just takes it. Nothing sloppy moving around and no more wincing by me when I can hear the engine move. Great stuff.
Per the question above, I torqued to 50 based on what other mounts recommended. Next time I have the car up, I'll get underneath to check and make sure they haven't loosened.
Below is a shot of the installed mount from each side.
**Oh, and forgive the bricks in the second shot. I have the jack and two jack stands in action. I add a stack of bricks because I'm always damn nervous under a car. Makes me feel only a little better.
