LOL WUHT. That literally does not explain anything. That's just bullet points that's irrelevant to the reason behind saying "MORE power".
I'm very honored to have your very post on this forum to be in my thread. It just so happens that your only rep is from someone in the same area as you and also made one of their first post in my threads.
If you guys are bored let me know.
In response to your questioning of spark plugs making the room to make additional power. If you don't follow the information that has already been posted, let me know what I need to clear up for you.
Consistent Ignition Corrections (When positive) will yield more power.
Knock prevention/Suppression will yield more power. How you might say? Well when these vehicles knock they switch their ignition strategy from "Fast Advance" to "Normal Advance" which will in turn change the amount of timing that is added, and the time that it takes to add the timing back in. This is AFTER it makes negative corrections to prevent another knock event moving forward. The ECU is very good about determining an up and coming knock event so it will make ignition corrections accordingly, however it doesn't always catch it and a knock event will occur. Negative corrections does not allow you to run target timing. Less timing = Less Power.
More timing = more power. I don't think I need to break this one down for you as it has been the result since the beginning of combustion engines.
