Dizzy Stage 2 on CA 91
Trader history for alex7 (0)
Winston-Salem, NC, USA
Is it possible you have your Dizzytune in econ mode instead of performance mode?
I really have no idea how to put it in econ mode, once I downloaded the tune to my accessport there was only one option, but currently I mark 25 psi of turbo so I really don't know what might be happening, anyway I'm just waiting complete 100 miles with this tune and then send the datalog to Jason
Hypergram
Orlando, FL, USA
Press CAN/RES then use speed up or down and watch the tachometer needle move. 2 is econ, 1 is performance
Hypergram
Orlando, FL, USA
Hi guys now my AFR is going to 15.30 and my OAR to -0.96
shoul I be worried about it?
When you're just chilling AFR should be around ~14, and wide open throttle less that 12. That OAR is fine. You wanna be as close to -1 as possible, with the range going up to +1.
Hypergram
Orlando, FL, USA
#30
should I do this with the car on??
Yes whenever you want. I usually cruise in econ but if I need to catch a light or something I'll just press the buttons without looking and use the extra boost. What you don't want to do is reflash a different tune with the car on. In the industry, that's what we call a big no-no.
Brooklyn
#31
I think the proper way to flash maps with the accessport is for the car to be on. I don't remember if mine even powers up when the car is off.
#34
Hi guys
I already have the answer form Jason of Dizzy and everything is great with the tune.
Now I have some doubts about the shift between every gear because my shift light from AP star blinkin really soon
so I do not know if it is better go to red line or shift once the AP shift light blink
#35
By the way, thank you very much for your advice and comments. Actually, now, I think that Tune is already completely adjusted, the numbers of AFR (14.70) and OAR (-1) are perfect.
Now at night I am scheduled to test the FIST against a GTI MK7 APR stage 2,
so if you can give me some advice you will be welcome, I really want to demonstrate the power of this car
Hypergram
Orlando, FL, USA
#36
Not too burst your bubble but you're gonna lose. That car on the APR tunes make crazy power. If you specified, you might have a launch control mode you can use now. Floor and clutch and gas in first gear at the same time and the car should hold the revs at a certain rpm. You can change that on the Accessport
#37
Yes, I think you're probably right but I want to prove how much the difference will be.
by the way according to your experience in how many RPM should I make the shift between gears?
Ford ST
Pleasant Garden
#38
I agree Volkswagens are heavily detuned from the factory lots of power left on the table.
Hypergram
Orlando, FL, USA
#39
Since the stock turbo dies after 5-5.5k revs you might wanna shift sometime shortly after that.
SoCal
#40
You won't regret it. I bought them during black friday where if you bought a 93 tune, you got an E30 tune for free! Maybe ask Jason if he plans on doing one of those again soon.
You’re right, I don’t regret it one bit!
I’ve had the tune for a week and I’m shocked at the difference. Already put about 350 miles on the tune and everything looks great. I’m going to have to use the economy tune a bit more, though. My right foot has gotten a little heavier this past week...
