NEW Product Release <<<<< HIGH-FLOW Turbo Inlet Elbow >>>>>
Valley of the Sun
#41
I realize this is a very old thread, but I wanted to share my experience with this first gen version of intake elbow. I had some spool up time lag from this. The only reason I figured this elbow was the culprite was by needing to switch back to the stock elbow when I had to take some internal measurements to install the S280 kit I bought a while back. I also had a strange whistling noise at part throttle (not turbine noise) that also went away after removing the whoosh elbow. There was also a slight increase in max boost, which was strange as well.
Comoaring the two elbows, there was a significant port mismatch between the stock turbo inlet and the Whoosh elbow, which likely was the cause of the issues I had. I did order one of the new elbows Ron came out with, so I can take advantage of the newer V2 elbow's design. Theres no way the plastic elbow will support the airflow needed by the S280 kit.
Valley of the Sun
#42
@ron@whoosh I ordered one of your V2 elbows and hope it will be a closer fit for the stock setup. Would you have an exact measurement in mm of the V2 elbow flange? I have to pull the S280 setup out for warrantee work (they won't pay if they see aftermarket engine parts), so I'll need to run a different elbow for now.
Thread Starter #43
I don't exchange or offer info on this forum anymore since they removed my nearly 10 years of posts in my section
There are many other ways to contact me for product info
